Map reset - We need a fresh start!
Date sent: 2015/04/18 21:33:03
It is not dreadful.. Every map has lasted 9 months, as has this one! 4 groups of people have had to go through a map reset, and they have lost all of their builds! Why is it being considered? Not because of greif, as you stated, it can jusf be rolled back! We are considering it as you have to travel hundreds of thousands of blocks away from spawn to find about 4 good chunks of land. Anyway, I voted yes that we SHOULD have a map reset, because Im readyfor a fresh start. Anyway, if you want to keep your builds, luigi usually copies and pastes them to the new map. Last map I had a huge city with about 8 skyscrapers, etc. I had to lose it! Arent you ready for a map reset? I am.
Date sent: 2015/04/19 17:45:00
Well this post absolutely failed!
Date sent: 2015/04/20 19:47:20
After careful consideration i have to vote yes.. There is far to much land not being utilized for new players to take advantage of. There has to be a way for them to reach area of wilderness with ease as when you are new you are vulnerable to everything around you. Including but not limited to players hiding in the ruins of yesterday. I love many and in fact all builds i have seen. That said we need to attract more players and having a massive mess everywhere and no where for the new players coming in to build is not an attractive way to advertise how awesome this server truly is.
When i first came to this server i was ambushed first by someone called assassin. Or something close to it..no matter. I still was captivated by what i saw and how many here were friendly and helpful. Though many continually griefed my house i continued because i saw what was possible if i just hung in there. I don't see many hang in there they just leave or get angry then leave because they can't find land to build. I voted to reset for these reasons and its tough because i worked hard on my builds and it ain't easy to see your things vanish into nothing.
On a side note it would be great because it may tease others to donate to keep this awesome server a live.
Gwen
Harveyc1
Date sent: 2015/04/21 06:24:54
hmm we might, it is possible since that lots of the Wilderness is ruined due to the population, so IF we do we need things planned, so yeah +1 :c
Date sent: 2015/04/21 10:06:02
Here is a compromise. Many people have been requesting a second world so why don't you make a whole new world and leave the original one alone. No complaints about griefed spawn, no over-populated 1st world and maby you might even be able to install the plugin that teleports people to a random place in the world. All the builds are safe and no complaints. I just finished alot of builds and i would hate for the map to be reset as they took a while to make as they are very large and a couple small.
Date sent: 2015/04/21 13:28:07
I agree with Dublin.
Date sent: 2015/04/21 14:19:15
Thats has already been done, it ended up with the old map becoming depopulated, and everyone eventually moved on to the new map. Then the old map closed due to 0 peopel on there.
Joshy01045
Date sent: 2015/04/22 10:05:07
+1 I agree with this completely. The wilderness has been ravaged from new people, most of which don't play on the server anymore. A fresh start would be great.
Date sent: 2015/04/28 11:58:20
Could we try the 2nd map again pls. If the chat and your inventory was connected then it !ight just work. Pls retry the map no 2
-Dub
Date sent: 2015/04/28 13:04:05
Date sent: 2015/04/28 23:47:46
Honestly, this map is getting old. There is inactive factions and griefs too old to fix everywhere. The area within about 5,000 blocks radius of spawn in mined out/claimed/useless. There are too many inactive factions and old griefs. There aren't enough readily available materials for new players and it's getting big and messy. I think we need a fresh start.
ARNJ
Date sent: 2015/05/05 03:26:17
-1 we just need a new spawn is seem lol
Harveyc1
Date sent: 2015/05/05 06:14:37
We could massively edit the spawn we have, that is a option :c
Date sent: 2015/05/05 07:08:59
Spawn isnt the problem. We dont have enough land to fit all of the 50 000 players that play regulary.
Travel further out of spawn, you say? No, as this makes the server load more chunks which will overload the server file.
