Inventory tweaks mod
Date sent: 2015/04/29 14:02:32
So I was wondering if I could install a mod called inventory tweaks. It does not add any items, just new controls. What it basically does is that it organizes chests eg if I had a a couple stax of cobble and other misc junk in a chest or any other inventory, as soon as I press the assigned key poof, it all gets sorted so tools at the top and like with like in nice neat orderly rows. It can also organize your inventory so that when you click a key a sword goes into slot 1, pick into slot 2 and so on. You can customize where they go but yeah, its pretty harmless. I recently installed veinminer by the consent of Luigi but it does not work on servers. I don't want to get banned for hax so what is your opinion; to install or not to install
-Dub
Date sent: 2015/04/29 20:22:15
This should be in suggestions.
Anyway however this is a modification of both the client and the server, meaning anyone joining the server requires to install the mod to even use it. Also I'm not totally sure or not if this requires forge. As soon as it needs forge we will no longer be a bukkit server.
Date sent: 2015/05/01 14:57:59
its a client mod like optifine so it can run on servers fine
Date sent: 2015/05/01 18:58:04
If that's the case then you don't need to ask for it, you should just install it.
Date sent: 2015/05/03 08:38:39
This mod is fine, but some other mods with gameplay effecting features (like fly mod, x-ray, etc.) can be classified as "hacks" or an unfair advantage against other players, which are prohibited by rule 2.
That's why it's always good to ask if the specific client-side mod is allowed or not.
Date sent: 2015/05/04 15:15:20
Is it also legal to have the double hotbar mod, it puts a second hotbar on your screen but it does not add any extra space. It uses the top row of slots in your inv and puts them bove your hotbar. Also waila, nei, armour HUD minimap etc are they legit. ill offer an explanation if requested. all they do are basically damage indicators and a bar on the top of the screen that tells you what pot effects you hace and the durability of your armour
