Most active players on the server in January 2018
Date sent: 2018/02/15 23:24:53
# Sorted by activity including afk time Sorted by activity without afk time
Username Hours Hours (no afk) % afk Username Hours Hours (no afk) % afk
1 Gilgamesh8 400.58 168.78 57.87% Soccergoalie25 336.12 335.76 0.11%
2 optic_penguin 354.59 65.72 81.47% Ranthar 344.98 288.73 16.31%
3 Ranthar 344.98 288.73 16.31% Sneakybubble 243.20 216.85 10.83%
4 Soccergoalie25 336.12 335.76 0.11% elliedlm 188.59 180.11 4.50%
5 Sneakybubble 243.20 216.85 10.83% SniffSnuff 183.53 175.24 4.52%
6 capnHawkbill 197.10 74.66 62.12% Viale 171.31 170.55 0.45%
7 elliedlm 188.59 180.11 4.50% Gilgamesh8 400.58 168.78 57.87%
8 SniffSnuff 183.53 175.24 4.52% CCShad 128.89 128.89 0.00%
9 DabbinDinosaur55 179.51 6.09 96.61% fredthedead276 120.12 116.75 2.80%
10 belgnbor 173.17 95.88 44.63% _nat_the_gamer_ 121.84 114.46 6.06%
11 Viale 171.31 170.55 0.45% belgnbor 173.17 95.88 44.63%
12 CCShad 128.89 128.89 0.00% Presinus 95.41 95.41 0.00%
13 _nat_the_gamer_ 121.84 114.46 6.06% Anj_ 92.82 86.84 6.43%
14 fredthedead276 120.12 116.75 2.80% QueenColor 79.37 79.27 0.12%
15 starcookie13 96.25 68.88 28.43% ImTyeDye 78.31 76.92 1.78%
16 Presinus 95.41 95.41 0.00% capnHawkbill 197.10 74.66 62.12%
17 Anj_ 92.82 86.84 6.43% starcookie13 96.25 68.88 28.43%
18 JellyJoe198 92.22 35.76 61.22% optic_penguin 354.59 65.72 81.47%
19 IceShadowSA 86.11 62.50 27.42% IceShadowSA 86.11 62.50 27.42%
20 Pr1tce 82.45 47.62 42.25% iBarry_Allen 59.44 59.14 0.50%
21 QueenColor 79.37 79.27 0.12% MasterCarla 57.03 57.03 0.00%
22 Pixelpeeps13 78.99 34.81 55.93% Loki570023 60.05 54.90 8.58%
23 ImTyeDye 78.31 76.92 1.78% FloppyFamburger 54.51 52.18 4.27%
24 Sauasgeman 78.13 20.78 73.41% Diamond_Launcher 51.45 51.14 0.60%
25 Omiticiyo 68.51 41.30 39.72% Songerie 50.34 48.95 2.75%
26 stojan44 66.43 18.16 72.67% Pr1tce 82.45 47.62 42.25%
27 Qwaczar 61.90 19.29 68.84% teejx 43.20 42.79 0.93%
28 Loki570023 60.05 54.90 8.58% Omiticiyo 68.51 41.30 39.72%
29 iBarry_Allen 59.44 59.14 0.50% MaxieLou 41.70 40.97 1.75%
30 Lizzyah 59.33 38.62 34.90% alpacafarm 43.92 40.86 6.96%
Date sent: 2018/02/15 23:34:23
I got fourth and first! woooo
pr1tce
Date sent: 2018/02/15 23:39:27
eyyy i made it!
Date sent: 2018/02/16 01:55:01
only 6 staff..im dissapointing as im on the list with 40 hours...
Pyrrhus
Date sent: 2018/02/16 04:10:06
I wonder how hard it will be to get 100% afk hours if it's possible
Date sent: 2018/02/17 01:02:50
It's not possible because the first 20 minutes after you join is considered not afk time regardless of whether you go afk immediately or not.
Date sent: 2018/02/17 17:03:52
What if you login the day before the month ends and start afking then?
Date sent: 2018/02/18 12:11:07
If you log in 24 hours before, 20 minutes will be considered active and 23h40m considered inactive, so that's 98.61% afk. In fact the closest you can get is logging in at the very start of the month, then being afk for the whole month, which is 31 days minus 20 minutes / 31 days = 99.95% afk
TooeleJedi
Date sent: 2018/02/22 00:26:46
luigio, what if said person logs on and types /afk immediately? if that took at most 2 seconds, that would be more than that.
Pyrrhus
Date sent: 2018/02/22 01:34:34
"It's not possible because the first 20 minutes after you join is considered not afk time regardless of whether you go afk immediately or not." , Lugi
