 brainiac529
Date sent: 2018/07/03 19:11:29
I think that the locking command is a great idea, but it is always annoying to have to manually lock things that don't auto-lock, such as the things stated in the title. I think there should be a command, where you can toggle an auto-lock mode. So either everything will automatically lock, or nothing will lock. Also, I would like to piggy-back off the idea, so it would also be nice if you could trust only certain people with all of your locked things, this would come in handy for things such as 2 or more person bases, and non-independent factions. I think anyone who is reading this post, also believes that that non-autolocking interactive blocks are annoying, so please consider giving this complaint +1, and, thanks for reading!
Regards, brainiac529 |
Date sent: 2018/07/03 21:32:09
define everything, it's a pretty vague statement.
This idea is flawed, because you're doing this under the assumption that nobody else you know would have any legitimate reasons for accessing your locked items. |
 MaxWreck
Date sent: 2018/07/03 22:58:01
I actually really like the idea. It's similar to "/f autoclaim".
So if i get it well, you do something like... Let's say : "/autoUnlock", and every chests or furnaces you place are unlocked, until you "/autoUnlock" again.
Should be in the suggestion section though. |
Date sent: 2018/07/04 05:14:52
+1 Exactly as Max stated |
Date sent: 2018/07/04 11:45:53
The command you are talking about already exists. Its called /lwc mode persist
typed exactly like that. When you enter this command, your LWC commands including things like /lock and /cmodify will persist as the name implies. This means that if i had a row of chests i wanted to lock quickly, i could type /lwc mode persist, and then do /lock. I would then be able to click every chest in quick succession without having to type the command every time, and they would lock. To disable lwc mode persist, you simply enter the command a second time. |
Date sent: 2018/07/04 14:30:48
All this time...
All those commands typed by hand...
They all said such a command didn't exist...
... I think I'm gonna cry |
 brainiac529
Date sent: 2018/07/04 18:42:52
loki why is that command not in /help?
Date sent: 2018/07/06 00:52:56
/cpersist is an alias of /lwc mode persist |
 Tye
Date sent: 2018/07/06 02:28:54
/pong needs to be fixed |
Date sent: 2018/07/06 16:38:26
For the same reason faction commands arent, brainiac
/help refers to essentials, whereas /f help is the faction help pages. LWC is a different plugin |
 JellyJoe198
Date sent: 2018/09/10 22:19:29
+1 this is definitely a good thing to try to implement, because even with /cpersist and /unlock you need to click each chest once after placing it, and it would be much easier if they were unlocked in the first place. |
