Forum Index > General > Spawn Example > Read the topic
Spawn Example
XxSotiriSxX
Date sent: 2018/07/24 13:04:32
So i tried making a spawn that suits the update perfectly and that's what i ended up with.
Date sent: 2018/07/24 16:25:17
Nah, lemme stop you here.
That's way to similar to the last spawn, we need something new than a building, with a thing in the middle, and boards on the sides.
I'm already working on it, calm down b.
XxSotiriSxX
Date sent: 2018/07/24 18:00:37
Whatever
Date sent: 2018/07/24 21:06:46
Somebody is salty
Date sent: 2018/07/25 04:04:52
avanzero
Date sent: 2018/07/25 04:37:26
This is really nice! Great job :)
XxSotiriSxX
Date sent: 2018/07/25 06:19:49
Thank you but im planning on making a few changes.
XxSotiriSxX
Date sent: 2018/07/25 11:12:05
Updated!
And added dolphins.
Date sent: 2018/07/25 16:23:57
Few things.
1. It's way too square.
2. We're gonna try not to have a singular building as spawn this time.
This is WAY too similar to the last one. If you even want a sliver of a chance, do something unique.
XxSotiriSxX
Date sent: 2018/07/25 16:26:42
Whatever just stop replying.
Date sent: 2018/07/25 18:53:12
If you want me to stop critiquing your work, stop bumping the post. I'll critique your work if I'd like to, and you should probably take my critique into consideration to improve your builds. Don't be salty just because you can improve. You're not the best, so take it at face value.
XxSotiriSxX
Date sent: 2018/07/25 19:19:26
If you think that by replying to you i bump my post you are completely wrong. Maybe ignoring you will be the way to go. And also i don't have something to get from improving my builds so i won't do so because 1 guy didn't like it. And what if it looks similar to the last spawn maybe that's a good thing, people will know here's the spawn and not just a build with signs on it. And also the hole minecraft is square, and my build is your chance to complain about squares ?
MaxWreck
Date sent: 2018/07/25 19:48:54
You should accept that he has a different opinion, evaluate if what he says can improve your build, then move on. Don't overthink his comments.
Date sent: 2018/07/25 21:12:14
Sotiris, you should really take my critique into consideration. I don't like to put myself up on a pedestal like this, but I know a thing or two about building, and so do a lot of other people on this server. All of them are willing to critique other players to help them improve, as we want to see them improve. You're really not helping yourself if you keep ignoring me.
Date sent: 2018/07/25 21:23:37
Ok, not gonna lie, that is way too small. I liked last world's spawn best. I'm not the best builder myself, so I'll just leave what I would accept as a spawn for others to build. I think a circular design would be best, with a Aquatic Theme to it.
Date sent: 2018/07/25 23:05:11
Oh you'll like our new spawn idea.
Date sent: 2018/07/26 01:34:17
Ok so I’ve played on here for a long time and here is my opinion on what works best as spawn-
Not a huge tryhard mineplex spawn- this is a survival server don’t try to make it something that it’s not.
Make the actual spawn a small building with some sort of garden or other feature surrounding it. The best example I can give of this is either the Big Ben spawn or the most recent remake of that quartz and brick spawn (can’t really remember what it was called). The Big Ben spawn had one building, similar to this one in the middle and was surrounding by gardens and ponds. The most recent quartz spawn remake worked well because it seperate the spawn town from the spawn it self with a small canal. What would, in my opinion, be ideal in terms of the new update and everything, is a small building with rules and staff, surrounded by a lake with bridges on each side to get across to the land where the spawn town would be. I think this is a concept that would work well. I might even hop on later to play a bit and try it out since I haven’t played in a good few months.
XxSotiriSxX
Date sent: 2018/07/26 04:50:41
@MaxWreck @Aouldrain @galbby5 <3
Date sent: 2018/07/30 04:06:28
I really like this design, but I've got some issues with it:
It has too many exits, just one would be ideal, two at most.
The sign boards have uneven dark prismarine and that triggers me deeply.
I can't tell where the actual block you spawn on is. Is it inside the pillar in the middle? or on a side somewhere?
We would have to replace the fish/dolphins every time somebody killed them.
Otherwise I think it's a really fitting design for 1.13. Fairly sized, block variety, nice flooring, etc.
Date sent: 2018/07/30 08:06:35
I dont think this would fit the server well, it reminds me too much of the last one. I really like the quartz spawn we had like 2 maps back. it went well with the spawn town
Date sent: 2018/07/30 09:28:21
I like it but would add a bit more depth to the water area have a bit more sea life in it, about 6-8 deep with kelp, seagrass and coral etc, maybe a just a few blocks wide to accommodate the sea life. Gathering top of the water is covered by glass to stop idiots killing the animals, and a bit more greenery outside. I agree with Cpt Space Sheep on keeping it a smallish building (which you have done) and plenty of room to build around spawn, disagree with ccshad as I like multiple exits, at least N, S, E & W. You need an area where people can mingle. Please keep expanding on this idea, its really nice. Also the centre should be the spawn point, still keeping the classic blue,yellow square.
XxSotiriSxX
Date sent: 2018/07/30 14:51:44
I agree with the idea to be more deep but unfortunately i built it in a superflat world so i couldn't build deeper. Maybe i will remove the pillar in the middle because i kinda forgot the spawn point. And also that i was thinking exactly that when i was building all the exits, I thought people would want to go to all directions.
XxSotiriSxX
Date sent: 2018/07/30 17:02:14
To be honest I forgot to add the spawning area and I'm thinking of removing part of the pillar. Also the uneven prismarine pillar it's just a modern design I used in my modern mansion and i though it can be used here as well. But if people don't like it I can easily change it with something more reliable. About the exits I thought that people would want to go out at all directions. @CCShad Image
XxSotiriSxX
Date sent: 2018/08/03 11:31:00
Made a few changes. I need help figuring out how to connect the pillar to the ground or even replacing it with something more suitable.Image
Date sent: 2018/08/03 15:30:45
That roof is terrible. You need to add more design than just "Purple Glass"
Date sent: 2018/08/03 16:30:58
In regards to the arguments about this spawn building, Dont forget ANYONE is allowed to submit a build as a spawn idea. There is no guarantee about it being accepted, particularly if multiple good builds are submitted as the staff usually come to an agreement about which one is best, with the owners (myself and luigi) having the final say regarding this matter.
Also, sotiris dont forget the spawn should be something the players ENJOY seeing, it should look good. So if a player offers ideas/criticism for improving the spawn you are trying to make, you should take it into account.
XxSotiriSxX
Date sent: 2018/09/01 08:44:06
I saw the latest realm and got an idea so I have completely updated the floor. Under the glass is supposed to be water and sea life. Also I would like some help for the roof from experienced builders like @Aouldrain.
Date sent: 2018/09/01 15:20:22
Few things.
Taking ideas from minecraft realms is less than optimal. Make something your own.
This is still, not good, just restart. The problem isn't parts of the build, it's the build itself. It's way to similar to last spawn.
Also, try not to make the spawn to incorperate new elements. It only makes it bad. If you have a spawn idea that INCLUDES the new update, that's good, try that out. But what you're doing, is building around 1.13, which you shouldn't, as it makes the build bad.
Date sent: 2018/09/01 23:14:39
I just looked at the realm thing an, jesus christ. What are you thinking? That's not taking inspiration, that's literally just copying it.
Date sent: 2018/09/02 02:23:07
How about for spawn, we make a sandstone model of Big Ben?
