Forum Index > General > Server Update 1.14 > Read the topic
Server Update 1.14
phatcow99
Date sent: 2019/04/23 16:16:44
Does anyone know when the server will be updated? I can't play at the moment because the server's out of date :(
Date sent: 2019/04/23 17:15:27
You can play, you just have to switch your launcher to 1.13.2
phatcow99
Date sent: 2019/04/23 17:48:06
how do I do that?
Miss_Sassy34
Date sent: 2019/04/23 21:21:59
You need to restart your game and then when it says play you can change the minecraft launcher to 1.13.2 phatcow99.
Date sent: 2019/04/24 08:52:06
The server is still on 1.13.2, but it's now compatible with 1.14 clients so you should be able to connect now.
The server will update to 1.14 sometime in the next 2 weeks, hopefully sooner than later, depending on when spigot 1.14 is released.
