Render distance - another issue that probably wont be fixed
Leklo375
Date sent: 2020/03/22 13:49:53
Its ya boi leklo here back at it again complaining about things that shouldn't be issues in the first place
today's issue? did you know that running a server on a render distance less than 10 causes Minecraft to freak the hell out?
here's proof
https://bugs.mojang.com/browse/MC-2536
now this isn't the only thing that lowering the render distance does, but its commonly accepted as far as I know that a server should never be below 10 chunks if it can help it.
Minecraft has a long history of render distance messing with its code even as recently as 1.14 where having a render distance higher than 12 caused many problems.
I know this probably wont get fixed but could we at least try? i mean come on playing with the render distance at 4 absolutely sucks.
anyhow thanks for reading
leklo
Ninon
Date sent: 2020/03/23 15:57:05
Leklo you disappoint me.
#1 It has always been this way. Always. The render distance is locked at 4 permanently.
#2 "should never be below 10 chunks if it can help it." Guess what buddy, we can't help it! The server is run on a 1990's microwave, and cannot handle even having mobs turned on 95% of the time.
#3 You should know that suggestions do nothing.
Date sent: 2020/03/26 01:33:01
We used to have the render distance at 10, that was over 7 years ago. Why do you think we reduced it to 4? Lag. It was unplayable on 1.10 even with 20 players (we used to be able to get 40-50 players back then with no lag). I know this because one time in 2014 or 2016 I think the render distance was mistakenly set back to 10 because the server.properties got corrupted and it was generated again.
Ninon
Date sent: 2020/03/26 15:05:40
See? Impossible.
legomine709
Date sent: 2020/04/14 00:56:03
Is there a plug in that can adjust the render distance based on current resources avalable to the server? This would mean we can have a higher render distance when not many people want to play but ad more join it allows the server to remain lag free.
Zabra
Date sent: 2020/04/14 00:56:53
Lego render distance has been increased now with the new host
legomine709
Date sent: 2020/04/14 00:57:56
Ah
legomine709
Date sent: 2020/04/14 00:58:27
I think this would still be nice to have tho if it can go higher
