 EdxTheFig
Date sent: 2020/07/15 07:14:18
This is the Map players will be in.
Thanks to the ones who joins during the Mini Event, I managed to iron out some issues that popped up during the first test.
Those issues have been fixed and this is the final version of the map that will be on Saturday
Some Info about the Event:
-Each Match will Last 10 Mins while in that time players will have to knock each other off the map or kill them
-The Score is based on who ends up with the least amount of Deaths before the end of the timer
-On the each corner of the map, Healing Stations can be found which will regenerate your health slowly. Due to them being on the corners its very risky to heal while players are near you as you may be knocked out
-Thought the map items can be found to use against players to give them a death or to help you from death, some items include an exploding snowball to a potion that weakens the player.
-At random times Super Items will spawn that give a large lead and give different effects that the normal yellow items do not provide
Item info will be posted at another time. See you Saturday! |
